Door Skins, Window Frames and Gaps
    As already mentioned by new-to-this, when fitting new door skins it's tricky getting the top gap between inner and outer shell to be correct.
    I've measured the thickness of the window frame (20mm) and the gap (21mm - 22mm), so the frame will drop in, but it's a tight squeeze.
    Can anyone peek a look at their Stag and tell me if that will be sufficient, or do the seals, chrome, weather strips, clips or what have you also need to squeeze into this gap alongside where the windscreen frame itself sits? (Front, quarter light and rear frame bits)
    Drew
