I fitted a Davies Craig fan last year and was not happy when we went to Brands as when it kicked in (low setting to test) nothing seemed to happen. well, time passes and other priorities come along.
So, now I come to check things over for next weekend I find I was right. However, I can't see the problem so need help. The fan documentation states it is supplied preconfigured for upstream mounting, in front of rad. I have a revotec switch and sensor in the rad and the wiring is:
perm 35A feed from battery to pin 30 on relay.
pin 85 on relay to earth.
pin 87 to live on fan
fan earthed.
No over-ride switch yet.
Fan works perfectly with switch although when it fires up the blades seem to rotate the wrong way. Air is pushed out of the grill rather pulled through.
The manual says to take the fan apart and reverse bolts etc. etc. but I don't have time.
Any suggestions? (other than bin it or live with it? :P)
fan earthed.
