Need to fit a ballast resistor to my 1972 stag, this has a RV83.5 fitted. With fuel injection and electronic ignition. (Ok don't boo and hiss its what I want, really it is), now then my problems are these:
The rev counter reads immediately over the top and drags the voltage down and stalls the car. So I've disconnected the rev counter supply to the coil. So now no direct 12V to the coil and no rev counter. I found a separate switched supply to supply the coil once the starter is released. To protect the coil and plugs I fitted a ballast resistor as per schematic drawings point 60 to point 13. Then went to start the car. The amount of heat that came off the resistor was huge it was glowing red hot. Almost a dead short. The resistance is 1.6 ohms so then it would be wouldn't it. What am I doing wrong here?
I was half expecting the electronic ignition to affect the rev counter. Is there anything i can do here ie will a MK2 rev counter work?
Mick
Mick
