Gent's returned home to UK late Friday eveening and went through yesterday to pick up my car from the panel beaters having waited 13 weeks for foot well replacement. All in all this was not a pleasurable experience as you might have read in my previous posts, but I gave this company the benifit of the doubt. Unfortunately I now find thatthe hood is now pretty much completely out of shape and sits squint when raised and before locking in position. The window zip is also now broken as a direct consequence of the state of the hood.
I can't seem to see where it's bent or if anything has slipped inside or around the mechanism. And Im wondering if the car body Chassis is distorted in some way which is causing the hood to sit raised up on the drivers side.
Initially this garage jacked the car up ,on the front passenger side at a ridiculous angle and flexing of the car body was evident at that time, but I thought that it would return to normal after I hit the roof and told them to jack it up evenly. The drivers door do's not now seal up to the rubber door seals, the window frame vibrates when driving as it is not pushed up against the rubber seals.
So has anyone any thoughts as to what would cause the distortion in the hood or am I getting paranoid, it may be that they just forced it down and have buggerd the frame. I am going to try and fit the hard top when it stops raining and this should tell me if there is any twisting of the car body I think. Unfortunately I am no mechanic or body expert
