Stromberg fixed jets
    If replacing the fixed jets, how far down the body should they be installed?
    Should they be flush with the top or about 3mm down as mine were previously?
    I believe they should be about 2mm below the surface,I'm sure someone else will be along very soon to confirm.
      Yep 2mm is correct.
      Nigel
      Mk2 1976 Delft Blue with Beige Interior. TV8 and ZF 4 Speed
        Hi Richard
        when I rebuilt my Strombergs last winter I learnt from a tel. call with Burlen Fuels that the original setting for the Stag was 100 thou / 2,54 mm. Worked fine for me - easy CO - tuning.
        Hope that helps.
        Klaus
          Thank you Klaus, and everybody else.
