wiring for instruments
    Hi Everyone
    I have put my instrument panel back having disconnected the wires in a rebuild. I thought I had written it all down but for reasons I won't bore you with no notes had been made.
    I think I have reconnected the instruments properly using the wiring diagram in the repair manual but I cannot be sure which terminals match which colour cables and I am concerned about accidentally transposing the wires on the terminals of each instrument and blowing something!
    Does anyone out there with a Mk2 1975 know which wire goes to which terminal on the instruments please? For sake of clarity imagine the dash is upright in front of you balanced on the steering column IE Voltmeter top left and the terminals are referenced from looking at the glass face of the instrument concerned.
    A mad request I know so I apologise in advance - and yes I do feel a bit silly!! Thanks for reading this and your help.
    Nik
    fear not
    volt,temp and fuel gauges are not polarity sensative
    alan
      Hi Nik
      I had all of my dash out a couple of months ago and I made a very rough diagram ofwhat went where.
      I've just looked back and my diagram isalmost illegible :?however if you'd like to PM me your email address, I can scan it and send it to you.
        Nik
        Here are my notes from when I removed the dash from my 1974 Mark 2. Hopefully they will be of use to you.
        All views taken from the rear of each gauge.
        Voltmeter
        bottom left : double white
        bottom right : double black
        top : bulb holder
        Temperature Gauge
        bottom left : blue
        bottom right : greentop : bulb holder
        Clock
        bottom : purple
        top : spare?
        right : bulb holder
        Fuel Gauge
        left : green
        right : green
        top : bulb holder
        Rev Counter
        top : bulb holder
        bottom : black
        right upper : double green
        right lower : grey/white
        Speedo
        top : bulb holder
        bottom : black
        far right : single green
        middle right : double green
        right nearest centre : double green
        Warning Light Cluster
        simply refit the plug
        Dimmer Switch
        bottom : red black
        middle : red/white
        top : red/white
        In the end I did not use the info myself. I have fitted a Mark 1 dash in the car as the walnut in my donor car was mint and I prefer the look of a Mark 1's gauges.
        Bruce
          Thanks Alan
            Brilliant thanks Bruce - I really appreciate your help.
              hi nik,
              been there bought the t shirt try this on line as pdf file shows uk and us www.vitessesteve.co.uk/PDF/stagwiring.pdf - Similar
              not sure how to many fancy link tab but i googled wiring for 1975 triumph stag
              go to first one(above address) its a pdf file download free not coloured though.
              hope this is some help.good luck and patience is a virtue comes to mind.
              ps check you have good batteries in your metre fooled me with some dodgy readings
              regards john.
                Nik
                Here is a coloured wiring diagram that might also help although what Bruce has given will most likely get you sorted.
                Nigel
                Mk2 1976 Delft Blue with Beige Interior. TV8 and ZF 4 Speed
                  thanks for your help - glad I am not the only one!!!
                  Nik
                    thanks Nigel - brilliant idea putting them in colour isnt it?
                      Yeah but I take no credit for it Nik. Another forum member did this a while back and thought it well worth keeping.
                      Good luck with the wiring.
                      Nigel
                        thanks John - good tip on the meter as well!
                        Nik
                          Originally posted by Rubce View Post
                          Nik
                          Voltmeter
                          top : bulb holder
                          Temperature Gauge
                          bottom left : blue
                          Clock
                          bottom : purple
                          top : spare?
                          right : bulb holder
                          Fuel Gauge
                          left : green
                          right : green
                          top : bulb holder
                          Rev Counter
                          top : bulb holder
                          bottom : black
                          Speedo
                          top : bulb holder
                          bottom : black
                          Dimmer Switch
                          bottom : red black
                          middle : red/white
                          top : red/white
                          Bruce
                          Thanks for posting this 4 years ago Bruce , the reason I didn't label mine is I just knew you would have done it
                          Edd
                            Edd
                            Hi Edd
                            You flatterer!
                            Bruce
