I have a Kenlowe 2000 series fan fitted to my Stag and in view of the recent hot weather decided that I would like to fit a manual override switch to be able to switch the fan on when things start getting a bit hot. I've bought a Kenlowe KLM0570 switch and fitted it this morning although I cannot get it to work.
Unfortunately the wiring diagram that came with my fan is for a positive earth vehicle. I connected the green wire coming out of the fan control unit to the middle of the switch. I then connected the positive terminal of the switch to a spare terminal behind the fusebox above the passenger side shelf (hopefully the +ve ignition controlled fused supply). The yellow wire from the fan control unit is already connected here. The switch earth terminal was then connected to a screw on the metal heater box. Could somebody tell me what I have done wrong.
As you can probably tell I'm not an auto electrician and so a non techy reply would be greatly appreciated. I've looked through previous posts on kenlowe fans and they don't seem to cover this.
Chris
Chris
