Rear Drive Sharft
    Rear Drive Sharft
    Can you fit greese nipple to drive sharfts and how do you do it
    Hi Dave,
    I did mine when I fitted new UJ's to my driveshafts. It is easy to fit grease nipples to the female half of the driveshafts while they are on the bench, and then just top up with constant velocity joint grease as required. You will see the rubber gaiter start to expand slightly as the grease fills the splines and spills out into the gaiter.
    The only possible problem is the danger of blowing off the blanking end cap which sits in the end of the female half of the driveshaft, when you fill it with grease. It will be obvious where it i when the drivesahft is on the bench - just make sure you check the end cap is held firmly in its position before you start pumping grease into the shaft.
    There are several threads on here on the size of nipple required and where to site it.
    Feel free to contact me if you cannot find it.
    hope this helps,
    Peter
      Hi Dave, Have a look at this :-
        thanks for reply where do you buy greese nipple from
          Your local motor factor should have then on the shelf
          ..........Andy
