Torque Convertor
    Torque Convertor
    Hi. Can anyone let me know, how do you tell the difference between the Type 35 and Type 65 auto box convertors.
    Cheers. Paul.
    Hi Paul, the part numbers for the 2 convertors are:
    Type 35 - 309168, Type 65 - RKC2115
    Not sure if the above helps you though.
      I found the same nubers in the book, I was thinking more on the physical side as they both look the same in the photos. I have one for sale and it would be nice to put the correct info.
      Cheers.
      Paul.
        I think a quick check is that the type 65 has a drain plug and the 35 does not. However, it's not unknown for the later pans to be retro fitted to the 35 so not 100%
          I wonder if they are interchangeable? It could be just the ratios that are slightly different (1:1 to 1:2 type 35 and 1:1 to 1.91:1 type 65 according to my haynes)
          not sure how you could check this:?
            I do believe a little bit more investigation is called for.
            Cheers.
            Paul
              Hi Paul
              Not sure if you got to the bottom of the difference between the type 36 & 65 auto box.
              Just reading through the Rimmer Bros catalogue and saw this:
              How to identify your gearbox:
              1970 to1976 - to LD41993, Type 35 - output drive/propshaft is splined.
              1976 onwards from LD41994, Type 65 - output drive/propshaft is flanged.
              Hope this helps.
