Performance Carburettor
    Has anyone tried a high performance, large bore 2-barrel downdraft carb on their stag? I am thinking something large bore that can suck a lot of air ie with no choke mechanism or air cleaner, and with intake trumpets?
    Please don't tempt me Chris, I've only just fitted the Weber, Terry
      No air cleaner,are you sure Chris?
      Cheers Steve
        Cheers Steve
        yeh, you know Steve, proper boy racer stuff
          Hi Chris, For my pennies worth, Be careful. A too large a two barrel carb will slow the air speed through the venturies too much and not completely atomise the fuel. This will loose performance and increase fuel consumption. A better answer is a four barrel,(Edelbrock 500 cuft.,Holley.) but I know fitting is alot more complicated and prohably need a new base welding into the inlet manifold.
          Cheers Ian A
            Cheers Ian A
            Hi Ian. Yes, low engine speeds may not be as good but this is a performance carburettor; so low speed economy is not important. I think this larger two-barrel idea will give best max power because the carb chokes are directly in line with the Stag manifold intake ports. IMO this gives better flow compared to the staggered offset port in the 4-barrell carbs. Maybe I will have to give it a go to prove that it does.
              just a thought but be carefull of bore wash when useing such a setup for road use could get expensive
              keeny
