no sorry martin
should have explained better used two seperate cables but my cable (when i pulled it out )was two cables crimped into the rod. cut off one nipple end then thread down outer cable from the carb end do the same with the other cable
by the way cycle ones are thicker 1.5mm but still pass through the outer
hope this helps
whibleg
hope this helps
whibleg
