i am under the impression that it is now recommended to use distilled water with anti freeze instead of ordinary water, is that correct ?
coolant water
Len, Dave's right all depends on where you live. We have pretty soft water here with no mineral deposits. You'll get a good idea what type of water you have by the condition of the inside of your kettle. If it's scaled up use ionised, distilled water. If your kettle is as clean as a whistle you should be ok with the water from the tap.
Originally posted by Stagdad View PostYours would be the soft area I bet Dave if my folks water in Gunnislake was anything to go by.Here in Berks you could knock nails in with it.Cheers Steve. No sign of any mineral deposits.
DaveDave
