electric window and another problem
Originally posted by Stimpy View PostNice one.
Im doing that sort of thing now. Good reminder about the puddle lights
Ok - come on ! Fess up!!
Immediately after your post try and guess what happened.....
Ready?
Puddle light on the N/S door.
Now seeing as you made this claim and - surprise surprise - it is the very thing that has happened then the guilty party is - obviously - here.
Ok -scrapping the attempt at comedy....
Can someone guide me on this one? ANY OF THE GOOD 'LECKIES HERE? I'll tell you what I have done.
First of all - basic analysis:-
fit fuse
open driver door - no issue - all ok.
Leave that door open
Go to passenger door.
Open it.
Other puddle light plus fuse desists
Part 2 - is it the bulb end, the door switch, or somewhere else?
Pull bulb out (by now I'm using a clamp and pointer bulb to test things)
With no bulb the fuse (number 1) still glows the pointer pen thing.
Part 3 - lay the seat flat and get a pillow.
Part 4 - slip down - upside down face up at bottom of glove compartment
Part 5 - With 'pen' clamped to the rear of the fuse nr 1 i poke about - i find a four point 'plug' assembly - I pull it apart. I touch the pen on each of the socket ends (obv the door is now isolated off) one of the sockets causes my pen to light - so I have found the guilty party. Sort of.
Part 6 - The annoying job of stripping off yards and yards of black tape to see where this cable is going - because as all the cables group they form a Y pattern (part of which I guess must be going through the fuse system).
Part 7 - With dust in my eyes and bare (plastic covered) cables above me - I find that it's a purple wire that is to blame and it appears to be going to within the 'stereo' area of the car - you know, the centre console area.
Part 8 - Log in to this site and type the above!
As a time reduction attempt (or T.R.A.) - can anyone offer me a good way to go forward?
At this stage I will end up unravelling all the looms from there black tape which I feel is a bit excessive.
Does what I mention above ring any bells or become obvious to a seasoned electrician (no insult to us learn as you work sorts!!)
Any help would be bloody fantastic.
Oh - and the relay has 'gone' as a result of all this. And I only just bought it.
Ready?
fit fuse
Open it.
Steve, I would check the wiring at the door switch and as it leaves the A post and enters the door first of all.
Ian.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Well - I pulled the block apart on the car side of the network. This is PRIOR to the door itself - imagine the door missing. As I touch the block terminal the 'shortage pen' lights up. God I hate wiring looms.Originally posted by milothedog View PostSteve, I would check the wiring at the door switch and as it leaves the A post and enters the door first of all.
A fundamental question. Am I correct in saying that if i put a crocodile clip on fuse holder 1 (no fuse in place) and touched the other clamp on fuse 1 and the light in the 'pen' then that's a bad sign?
then....
If I clamp the crocodile on any earth and put the pointer in the (opened) connection block and touch each one of the 4 points then equally I should not see the pen glow?
I'm sort of stepping back a bit and doing diagrams and thinking - hence the simplistic question above
Originally posted by Stimpy View PostA fundamental question. Am I correct in saying that if i put a crocodile clip on fuse holder 1 (no fuse in place) and touched the other clamp on fuse 1 and the light in the 'pen' then that's a bad sign? If the door is open your test light acts as the fuse and it would come on, if it comes on with the door shut then you have a problem. (the fuse should blow as soon as you replace it in this case)
then....
If I clamp the crocodile on any earth and put the pointer in the (opened) connection block and touch each one of the 4 points then equally I should not see the pen glow? if the fuse is in place, yes.
Steve, If I understand you correctly, see above. There are 2 different circuits for the interior lamps on a Stag I believe, there are switches with 2 wires and switches with 1 wire. you need to identify what you have and then work from the approperiate drawing.
Ian is quite right however there was never an official wiring diagram for the 1 wire switch arrangement (Ie The single black wire to the door switches that earthed when the door was opened).Originally posted by milothedog View PostThere are 2 different circuits for the interior lamps on a Stag I believe, there are switches with 2 wires and switches with 1 wire. you need to identify what you have and then work from the approperiate drawing.
Here are a couple of unofficial, but correct, diagrams for that (1 wire) system: - (not my work but from the tech pages)
Just a quirky.
Wouldn't it be easier not to have a relay at all? After all - it's to like powering 100w spots or anything
or
For each electric window button give it it's own relate switch and then go straight to the windows?
Option 2 would at least allow you to have a window working if the other has issues
I went out and bought 2 '5-pin relays'
Do you think that I can let the windows have their very own relay? Surely it's do-able
I've rewired the door lights (they were in a bad way) ask this goes to the fuse box. There are now 2 wires coming from the door - Is it not obvious that these are for the windows?
In which case if there is a wire each cable good go up or dow
Alternatively one of the cables could be earth and the single air does the up and dow.
It's driving me nuts because I have spent hours on the dam thing.
Can someone tall me before I find a tall building to hurl me off!! :
Cables and relays - jeesh)
M.
