Hello There.
I have just bought a MK2 Stag and when I put the lights onto high beam nothing happens the main beam is fine but high beam there is nothing. Can i change the bulbs or is it a sealed system. Thanks Kevin
. In your case however (going by the fact that both are not working) I would say that you have a wiring issue, probably dirty contacts My first port of call would be to check for voltage at various points and work back (the connectors at the front of the car for the headlights can corrode/oxidise leaving you with no lights, or intermittent lights).
