Jangling sound doing my nut...
    Ever since I've had the car, about two years, there's been a jangling sound from the rear which manifests itself when I go over rough ground or a bump. I've been under the car, I've tightened every nut and bolt, I've had stuff out of the boot all to no avail. It's really been fizzing my p*ss and I've been resigned to trying to tune it out.
    Then I took a mate out down the pub today. When we pulled up in the car park he said to me 'I don't know how you put up with those wheel boss discs jangling, that would really annoy me.' Sure enough he was right - the clips holding the aluminium discs in place are a little weak, allowing the discs to rattle around.
    If you too are afflicted with a jangling sound and can't work out what it is, have a look at those discs and either get some more clips or bung them up with some clear silicon sealant.
    well thanks Richard, i have a jangling too, sounds like a wire coat hanger round the prop, very slight, but there, i too have been all over the car, never found anything at all, i will be checking mine now.
    thanks
    Alan
      thanks
      Alan
      Its usually the hand brake cable hitting the propshaft, try pulling the handbrake up a notch or two to see if it stops.
      John.
        Also had the jingles in the back. Sounded like Santa Claus pulling up from behind I put some felt between the hub disc an the spring - all silent (night?) now.
          Hi John, will try that too, thanks, my hand brake only ratchets 4 or 5 clicks to full on so i never even contemplated that one,
          thanks
          Alan
