Heater.
The German Owner's Manual has a pic of the Air Conditioning heater flaps and their functions. Basically the same for the non-AirCon models. The useful text (What flap is what and is controlled by what lever) is in english.
Page 026.jpgThe answer isn't 42, it's 1/137
Originally posted by dasadrew View PostThe German Owner's Manual has a pic of the Air Conditioning heater flaps and their functions. Basically the same for the non-AirCon models. The useful text (What flap is what and is controlled by what lever) is in english.
[ATTACH=CONFIG]18717[/ATTACH]
If you've got five minutes, is there any chance of you doing a rough translation of the second schematic ?
It'd be much appreciated if you could- You don't need to worry about the first couple of words after the Letters A,B & C
Here you go Julian. Don't forget the description is for air-conditioning models.
A: FRESH RECIRC (Fresh Air Circulation) - Flap is controlled by Lever A (see pic on previous page)
B: COLD/OFF/HOT - these flaps are controlled by Lever B. (see pic on previous page). Both of the flaps are then moved into position by the vacuum servo actuator. There is no intermediate position
C: SCREEN/CAR - these flaps are controlled by the Lever C (see pic on previous page)
- Circulation air inlet
- Fresh Air inlet
- Air flow from the plenum via two fans on each side into the respective zone
- heater matrix (this is the lower flat oblong in the diagram)
- Water outlet from the plenum
- Footwell outlet
- Windscreen outlet
- Water and dust outlet opening
- Air cooler (this is the vertical dark oblong in the diagram)
- Air grille in dashboard
- Air vent in the middle of the dashboard
Originally posted by Staghound View PostI took my Stag heater apart a while back,inevitably I can't remember what goes where......Do any of you fine chaps know where I can locate a drawing showing an exploded view??
Thanks Andrew.Halfords wipers, Turtle wax and shampoo - RV8 and a beautiful Rover 75 ("relax it's a Rover")
Originally posted by Staghound View PostI most humbly thank you all for your help in his matter, it will take a lot of the guess work out of the reassembly.
Many THANKS, Andrew.
DrewThe answer isn't 42, it's 1/137
Originally posted by Mike Stevens View PostAll that info is in the repair manual anyway - even in the English version on pages 82-25-00 sheets 1-4! A scanned version is available online - somewhere.
It sure doesn't do any harm to have it all confirmed anyway!
I have a paper copy as well as the downloaded PDF one. The latter is useful for printing off odd pages rather than putting more oily thumbprints on the paper version!
I enjoyed our chat last Friday....
Mike.Mine since 1987. Finished a 20+ year rebuild in 2012. One of many Triumphs and a 1949 LandRover!
