Still keep a look out for residual pressure in the cooling system Bruce (assuming your system does hold pressure).
The expansion tank system can cope with small amounts of combustion gasses in the cooling system on short journey hot and cold cycles, but on longer journeys it simply forces all the coolant out.
Also a slight leak on the water pump may allow air to draw into the system as the engine cools as it has to suck the water uphill. With a header tank system the seal is under positive pressure all the time so a puddle will gradually appear in the V, My Stag engined Estate has been like this for three years, but the leak is getting slower.
