Gauges behaving strange
    Hi
    Was out driving in the sun today when suddenly the water temperature indicator dropped from half to quarter and the fuelgauge from half to almost zero. After 5 miles or so they both likewise suddenly was OK again. Any thougts on what could have caused that?
    Bo
    Maybe the voltage stabiliser playing up which attached to the back of the speedo...
    Sam
      Sam
      I agree with Sam, voltage stabiliser. An easy and cheap fix for a change!
      Mark
        Hi
        Thanks both of you for advice. And for adviceing an easy and cheap fix... :-)
        Anyone know if this is a standard Lucas part or a "Stag-special"?
        Bo
          standard lucarse
          but before condemning it make sure it is earthed!
          There should be an earth lead connected to the body of the speedo but it can drop off.
            Good advice Richard..
            Sam
              Will check that before any purchase....
              Bo
                yeh make sure its earthed-fitted a replacement-couldn't be bothered to fiddle and get old one off back of speedo so just taped up and pushed to back of dash oh no doesn't work-fitted earth wire-spot on
                  Hi again
                  Tightend the earth-cable and since then everything is working perfect. Since it been a while i guess/hope that´s it.
                  Thanks!
                  Bo
