bonnet Strut
    Alister
    The struts that I used came off a Citroen C4 ( 51 reg I think) bonnet. I had to redo the mountings and make new ones to fit my application, the max length between mounting centers is 490mm. I made up the mounting brackets to fit the original holes in the stag bodywork.( I dont like drilling any extra holes in the bodywork)
    Les.
      Originally posted by peterrc View Post
      Would it not be possible to thread the lower end of the strut and fit a penny washer and wing nut to lock it? It would be advisable to do this on both sides to avoid twisting.
      Peter
      If I have understood correctly, you are suggesting threading the shiny steel rod which is extremely hard metal. If you did manage to thread it, the theads would tear up the seals inside the strut when compressed.
      Apart from this a good idea.
        The struts are a thing I would like to do one day, Ginger Moles look good.
          Could have explained it better. I meant the existing strut. I said it out of memory as my Stag is in storage. having looked at the Rimmers website I do not think that it would work.
          Peter
