Hi All,
Began winter overhaul after buying Stag in October and being laid up after operation on my shoulder I set about fitting external water pump, re-locating alternator, stripping and cleaning carbs, removing sump to check mains/big ends, replacing front pulley oil seal, removing and checking oil pump, romping distributor to clean and fit Accuspark electronic ignition (to replace ageing Luminition), new dist cap rotor and leads now I can't get it to fire up.
I've check the distributor, TDC marks on front pulley aligned and rotor pointing to no.2 but nothing, checked all wiring i've touched/cleaned, checked carb float levels etc, getting cold and fed up, any suggestions would be gratefully accepted.
