Originally posted by milothedog
View Post
Slow leccy windows
Hi Ian,Originally posted by milothedog View PostBefore you delve to deep Steve it may be worth by passsing the thermal device and see how they are. IIRC both windows share it, so it's is common to both of them and you say there both slow.
When you're up against a problem, anything is worth trying ! However, isn't the thermal device a straightforward ON/OFF system ? If so, I would have thought it was just yes or no ....bit like a Virgin
Like you say Julian anything easy is worth a try, but any component can offer a resistance if only at its connections. A quick check by putting a volt meter in parallel will show this. In other applications I have known them play up and we used to cut them out the circuit and replace them with a tripping blade fuse and holder. I suggested bypassing it as it is shared by both windows, so as I said common to both and both are slow
Last edited by milothedog; 22 March 2015, 11:41.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Of all the descriptions of electrical devices, I havent come across that one before Julian. It would certainly liven up any text book or lecture.Originally posted by jleyton View PostHi Ian,
Although a thermal fuse is basically an on/off device, it and its connections will have some resistance which saps voltage when current flows through it.
