Hi all,
I joined the club last year, but this is the first time I've used the Forum. I'm living in the west of Ireland, so I've very little access to knowledge or guidance on the Stag's peculiarities. I have a Tropical blue 1977 Stag. Running reasonably well since I got it 18 months ago.
I have been advised to change the timing chains, so I decided to do it myself, to get to know things a bit better and identify any other pending problems that should be attended to.
I've a few questions that I need answers to on the timing chains.
When looking in at the sprockets with the timing chain cover off, and the crank and cam sprockets at their markings for piston 2 at TDC, the Jack shaft sprocket is not as described in the manual (scribe line at just below the 3:00 0 clock position). It's either at the 05:00 o clock position or the 02:30 position. The engine was running fine before I opened it up, so could someone explain what is happening.
The chain tensioners that I got from Rimmer Bros do not have oil ports in them as described in the manual. Has there been a design changed with these ?
The sump gasket got damaged while loosening the joint to get the timing chain cover off. Can I avoid taking the sump off to clean and close the joint?
Looking forward to hearing from you.
Regards, Brian
Regards, Brian
