Originally posted by elvimto
View Post
Cooling advice
Guest
I have noticed that a lot of us are flushing our systems a lot.
I sincerely hope we are using distilled water for the refill after the flush.
Originally posted by Knockwurst View PostNope. For what reason?
You only have to look in the bottom of my kettle to see why, and I empty it out every day.
I use water from the dehumidifier. We have plenty due to the inherent damp in the farmhouse!
NeilNeil
A quick update, checked the coolant level, ran the car from cold, it took about 10 mins to open the thermostat when idling.
took a short drive about 8 miles, temp gauge stayed in the middle of the gauge.
once cooled checked coolant level, all ok, after the drive the IR thermometer read 82 deg at the temp sender at the back of the head.Looks like an air lock caused the quick temp rise
I'll continue to monitor the situation, I was a bit nervous when I found out a thermostat wasn't fitted. The PO ran the car only a couple times in the summer, the rest of the time it sat, maybe that was why the thermostat was removed.
Thanks for all the advice.
