fuel tank pics
To be honest as long as they are both vented to atmosphere under the car, that's all that matters. otherwise you end up with petrol fumes inside car
We may never know what and when and if things were changed during production.
IanWise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Originally posted by HersnotHis View PostOK have now found it thanks to all ! I was yesterday looking for the elbow which looked like it was metal in the pictures in the earlier posts. It is not blocked but just had a very short piece of thin black tubing covering its length.
Have received new fuel pump from LD this morning so while fitting it I will restore correct venting.
Next question however is where do these vent and drain tubes go at the other end? I can see no holes in the boot floor when viewed from under the car. Similarly in the O/S wheel arch but the lower rear of this is obscured by the mudflap.
If I have to drill holes where should they be?Dave
Originally posted by DJT View PostJulian's photo in post #22 shows clearly where they exit the boot. Looking from underneath one will be through the boot floor and one through the vertical panel just above the floor. The pictures I took of mine with the tank out are exactly like Julian's.
I wonder if there was a change of routing DaveMine looks original and the Rimmer's illustration suggest that the spill tube was shorter and went straight down as on my car
I don't seem to recall that hole in the vertical panel when I had my tank out eitherespecially as I renewed all the grommets when I removed the Tow Bar.
Last edited by milothedog; 11 April 2015, 18:33.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Originally posted by milothedog View PostI wonder if there was a change of routing DaveMine looks original and the Rimmer's illustration suggest that the spill tube was shorter and went straight down as on my car
Since you have recently fitted the Ecco pump from LD I am sending you a PM in the hope you can clarify one or two aspects.
Thanks
H
Strange as ours are but a few numbers apart. Mine also looks original.....Dave
Originally posted by DJT View PostStrange as ours are but a few numbers apart. Mine also looks original.....
My car has been down to a bare shell by a PO, maybe it got put back differently, but like I said the Rimmer's illustration shows it as a short pipe and there is the picture of Edd's car with the wing cut away that appears to the same as mineWise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
