Trying to help a friend and he has the following choke knob fitted and we cant get it off. On my one there is a grub screw and on the original ones I believe they had just a pin that you could press in and off it pulled.
Looking at his set up he has neither and looks like a pin that has been punched to for a rivet. I cant understand also as to why a hole would be so close to the end as surely it is a weal edge.
With enough force, will this pull off or will I have to drill out the pin that has been flattened?
What have the rest of you got fitted and how?
Andrew
Andrew
