Hello!
Unfortunately the answer is "yes."
I had a noise come from the gearbox when letting up the clutch whilst the car was at rest. However, once the car was moving, the gearbox was silent.
The garage that installed it obviously had problems as they had extended the clutch slave push rod to get enough "release bearing travel."
To ensure they had got the bearing in the right place, they had drilled an inspection hole in the bell housing of the gearbox and later covered it with a metal plate and four screws.
I took some pictures to show what I found;
1. Clutch slave push rod and inspection plate.
2. Clutch in place behind spring plate showing "flywheel side" written on flywheel.
3. Worn down spring retainers on clutch friction plate.
4. Close up of wear.
5. Crankshaft flywheel bolts with the corners knocked off where the spring retainers have hit them.
If you see these tell tale signs - you know what's happened.
Regards,
IMG_20160124_130348.jpgbefore removal - see writing.jpgfriction plate.jpgfriction plate wear.jpgfiled bolts.jpg
Regards,
He/She ever got he job,or the lack of training / supervision they had ,hope they don't do brakes !!!!!
