original oil filter leak
    Hi all,
    Yet again the large O-ring at the base of my original type oil filter has failed.
    I'm pretty sure I'm doing nothing wrong and I'm torquing it to 20lb/ft (as per Haynes manual).
    Is it just that the square section O-ring is poor quality, can I use a different O-ring of the same dimension, or even back-up the original with a good quality sealant?
    I've been using Classic Gold filters from Paddocks.
    Mark.
    There is a difference between the o rings supplied with the various filters - you have to be sure you have the right one in.
    If you have doubts or worries about the filter ring, contact Peter at LD - he'll get you straight
      Thanks again Russ!
      I'll call him tomorrow.
      Mark
        Originally posted by Stagnant View Post
        Thanks again Russ!
        Mark
        Mark pm me your address will post you a spare I have, just let me check
        The minilite team
          The minilite team
          Pm sent mark
            Posted, you should get it tomorrow, 1st class stamp
              Nice one Martin.
                Spread the sunshine
                  Originally posted by Andrew S View Post
                  Spread the sunshine
                  A yellow East Anglia - my vision for the future!
                    It turned up this morning, as promised! I wont be able to fit it till tomorrow, but at first look it appears quite a bit 'meatier' than the one that comes with the Classic Gold filter so thanks again Martin 'cos I'm going to Euston Hall on Sunday and was a bit worried about the journey.
                    Mark.
                      We may need a referendum on that
                        Vote Yellow on the 23d or the world will end............
                          Put me as +1
