Just ran the car up the little side road and back a couple of times. Temp. gauge seems to like a bit of fresh air coming through the radiator so that might point me in the direction of an electric fan.
Temperatures are basically between 71°C and 82°C with the exception of the LH Transfer Housing which is 88°C and, of course, where my overtemperature warning switch is fitted.
Hottest points are the transfer housings at 82°C and 88°C
Top Hose around 71°C
Hose to heater around 74°C
Return from heater (set to blow hot air) around 66°C
A couple of other bits around the radiator 74°C
It's quite a hot day here at 24°C in the shade, and the car is in the sun.
How does all that sound?
Drew
Drew
