My Stag rebuild is just about finished. After 4 years my ride has a Rover 3.9 EFI V8, HP24 autobox (Jaguar), and BMW rear end (LSD 3.57:1). The engine is running fine and after a few jumps and starts holding a nice temperature. But the original Stag temperature gauge is reading way past the red zone. I tested it with a gauge tester and it was reading just past normal. After a glorious drive back home from the garage the needle went off the scale after 5 mins but when I opened the bonnet after the 25 minute drive the engine was fine, the top hose warm not hot, same for bottom hose, engine warm, and nothing coming from the header tank overflow pipe. A friend who has a Ford Cosworth said he had a temp gauge misfunction similarly when he used a standard Ford Sierra temp gauge. The question is: Is it possible the Rover temp sender is not compatible with the original temp gauge or is it that the 42 year old gauge has had its chips?
Ralph
Ralph
