Originally posted by garyf
View Post
Led instrument lamps
Originally posted by dasadrew View PostIs it really necessary to modify the warning light cluster? Although my clocks are dim, the warning segments are really bright with (new) standard bulbs.Dave
Originally posted by garyf View PostThese are great but I have a mk1 dash
Are the mk1 instruments inherently poor when it comes to night illumination ?
Originally posted by DJT View PostI haven't seen the need to, Drew. The main problem with the cluster is that correct bulbs don't seem to be available any more, either LED or incandescent, due to 'standardisation'.
Drew
Guest
Originally posted by Stagdad View PostA bit of work but good results can be had from installing red,green,blue LED strips in the cans of the gauges and using a cheap controller to determine the colour ( about 20 to chose from)depending on your mood and has a dimming option
[ATTACH=CONFIG]41433[/ATTACH][ATTACH=CONFIG]41434[/ATTACH][ATTACH=CONFIG]41435[/ATTACH]
Thanks
HLast edited by HersnotHis; 27 July 2017, 20:57.
Hi Steve
Followed your advice and fitted the LED's from Classic Car LEDs. Simple and straight forward job and a big improvement. However, I have found two issues.
1) My vault meter showed no charging with the LED installed but I read somewhere that the Led did not draw enough current to 'kick start the alternator. Reinstalled the filament bulb and that cured the problem.
2) With oil light LED installed the brake system warning light does not glow dimly when the ignition is turned on. IS this becauese of low current draw also do you know?
Have you experienced these issues with you installation?
I have a 1974 mark 2 Stag.
