Stag failed MOT as I said a few days ago. The fuel tank was leaking and I received my 2nd hand replacement today. All seemed well. After a couple of hrs I went out to check it.
My replacement has a drain plug which the original did not and it had a very very slight leak from the drain plug. I tightened the bolt and it is now worse
Rimmers site show a fibre washer WF524- anyone know what size this is? so I can get one locally. Plus I put more fuel in before the problem arose so I have about 7 gallons in the tank too
Darren
Darren
hi darren, i use a product from loctite called 577.use it all the time for fuel lines in my daily work never ever let me down.i do not rely on washers or ptfe alone.
