next months article
    next months article
    apart from the obvious trawl through and a previous suggestion to cover how Don being able to join in the debate on here andending up buying a stag and joining the SOC as a result (this is in) I look forward to your suggestions to form the basis of the article.
    You'll be asking us to write it for you next.......
      You could mention that new quarterlight rubbers are on their way!
        Russ, I only pull together the suggestions, make the java references and the odd attempt at humour, though if you are volunteering...........
          How about:
          How robust the Stag is ( http://stagownersclub.mywowbb.com/forum1/3688.html ) even pulling out a stuck VW!
          or how the Stag is helping to teach physics to todays youth ( http://stagownersclub.mywowbb.com/forum1/3693.html ).
          dodgy kevlar hoses still being sold by major suppliers ( http://stagownersclub.mywowbb.com/forum1/3673.html )
          stainless steel bumpers
          fixing stripped spark plug threads
          best jacking points
          Quarterlight rubbers (hopefully soon to be remanufactured)
          parts qualilty again!
          supercharger updates
          that'll do for starters!
          D
            What about ROVER V8 CONVERSTIONS
            Adrian
              Dave has made the job very easy - thanks Dave! Will you be at the Blacksmiths Tuesday?
                How about the thread on delicate Stags - do not believe it. Good for the Stags image...
                  Hi Graham,
                  Unfortunately I won't :X. I am in Birmingham on a course all week. It is the same reason that I wasn't there last month. flippin' annoying really.
                  Say hi to everyone for me. I should make March with a bit of luck
                    How about a request for Stag Forum Members to submit (sensible) ideas for the best way of beating the "Credit Crunch" & thereby keeping their Stags running efficiently at minimum cost, and not having to put them up for Sale as some who have been unfortunate to have lost their jobs due to the crises have had to do!
                      Terry - can you define 'minimum cost' as it relates to the Stag:P
                        Very true, I am still surprised that there is a very high premium placed on stag parts..recently I was researching brake discs and was interested in the super duper grooved ones from EBC but at £177 for a pair thought..no way... next to consider were the Rossini discs again in the same ball park! Tony Hart had the cheapest drilled discs at about £140 (I think..Tony put me right if you like!).
                        But in the end being a Tight Wad have gone a different route... Maye the car we love should be known as the $tag.................
                        $$$$$$$$sssssssssssstag.............
                          ...Whatever you consider would fit at the lower end of your recently revised Stag/Cars Expenditure Budget..... I'm not a Statistician and it would probably vary for everyone ..... but whatever doesn't make SWMBO scream "HOW MUCH"!!!
