stagmuffin wrote:
Hi Steve,
There is a small shuttle valve that runs inside the solenoid assembly, it has a couple of small dia orings (approx 6mm) these can harden/swell/split over time and cause the shuttle valve to stick with the overdrive on, especially when the engine is up to temperature. It's a bit of a pig to remove from the solenoid, especially if the orings haveaged as mentioned, when you reinstall it use lots of gearbox oil to lubricate the orings.
I'm going to be in Luton (Stopsley) in the second/third week of Sept staying with a Stag owning mate of mine, if you fancy a pint one evening?
regards,
Raoul
stagmuffin wrote:
:?hi raoul, shuttle valve o rings is this another valve in the od unit?? where is it located ??got a new solenoid to fit and have made a spanner to your design as pic i aim to clean the strainer and have just ordered a new gasket for o/d sump but sounds like i need to get these o rings to be on the safe side.
or am i mixed up and you mean the ones on the solenoid assy.
cheers steve.............
regards,
Raoul
hi raoul, got it in bits this morning and it would seem the solenoid is at fault but got a recon unit to fit from paddocks to save off road time .will take old unit apart to investigate before i return under exchange. it was only £41 +vat so worth the punt.
let me know when im only in warden hills area about 5 miles away .
