ATF Preferred Type & Top-Up
    My ATF could do with a top up and was wondering what make / type / number us auto folk use? With previous auto's ive had you just topped it up via the dipstick tube, is this the case with the Stag BW35??
    Kind Regards & thanks in advance.
    Russell
    only ever topped mine up once didnt look at the make of it and put it down the dipstick tube, i think thats the only way to fill an auto box.
      Hi Russell.
      The only thing I have picked up on since being on the forum isDO NOT use a Dexron II or III type fluid as these are not suitable for the BW35.
      Rgds....Al
        Andy many thanks mate.
        Al - superb thank you mate V Much appreciated, it wont be a 2 or 3 i buy tommorrow!! Cheers
          arbman101 wrote:
          Hi Russell.
          Rgds....Al
          HERE HERE - NO DEXRON ! Martin.
            Cheers mate, No dexron it is!
              Anyone give me a make and model they have successfully used?
                This is the stuff I use Comma AQF
                http://www.commaoil.com/Product%20Pa...nlubes/AQF.htm
                  Brill!!! Thank you!!!
                  "Approved for use in Borg Warner automatic transmissions and torque converters"
                  LIKE THAT BIT!!
                    I have picked it up at the local motor factors and Allparts with no problems, did find that if your not careful and end up at "Halfords" they would tell you that the modern fluids would be ok for "older gearboxes" a big NO NO!
                      Thats great, thanks for your help mate! Got a note of it and will go to the wee motor factors round the corner tommorrow!
                        Got some cheers folks, 5 litres of the Comma above
                          Should last you forever Russell unless you end up with an horrendous leak!!!!!!!!
                          Be sure not to overfill it.
                          Nigel
                          Mk2 1976 Delft Blue with Beige Interior. TV8 and ZF 4 Speed
                            Hiya Russell, if you decide to change your fluid, leave it to drain overnight, the faulty non-return valve will allow the torque converter to partially empty, then you'll need about 6 1/2 litres. Is your fluid red, maroon or brown ? Martin.
                              Hi mate, was just topping up as i have a slight (very slight, not sure where from yet) leak, so was on the bottom level so ive topped it up, but its red alright
