My green stuff pads are coming up for replacement after about 16.000 miles, I'm a bit disappointed at the mileage, but I have found them to be superior, better braking and much less dust, any thoughts guys ? :? Martin.
GREEN STUFF.
	 GuestTags: None GuestTags: None
	 Russell Russell
 Martin Stevenson wrote:Auto or Manual Martin ? Auto will always need more brake use - i'd normally rekon on 15-20000 milesper pad set for MOD, you are not that far out.My green stuff pads are coming up for replacement after about 16.000 miles, I'm a bit disappointed at the mileage, but I have found them to be superior, better braking and much less dust, any thoughts guys ? :? Martin.
 My Greenstuff pads are only 5K old and still in good order
 .....Andy
	 Guest Guest
 Hiya, they do deposit dust, but not nearly as much as standard pads, and the discs don't appear to have worn more than usual.I think I will go for them again, based on the mileage comments from you guys. A big thank you. Martin. Martin.
 - I might give them a try then
