Got my Stag back from the mechanics a few weeks ago after some fairly extensive and expensive mechanical and electrical work. Got about 2 miles up the road when the oil light came on, so I drove it straight back! They checked the level and it was fine, and blamed the sender. Figured its MOT was due in a couple of months anyway so I'd just get it done when I brought it in for that.
After driving it for a bit though, I've noticed when the engine is cold, the light is only on at idle and disappears when the engine is revved. Once the oil has reached running temperature, the light stays on all the time. This to me doesn't seem like a dodgy sender. I'm planning on taking it back again but not sure they've done anything that could have upset the oil system - they replaced water pump and cam cover gaskets but that's about it, so no need to go draining oil I'm assuming.
How worried should I be about this? I don't plan on driving it again until I've sorted it, but I've already covered 50 or so miles (no worrying noises). Have read it could be anything from clogged filter to dodgy sender to knackered bottom end! Unfortunately I don't have an oil pressure gauge fitted.
