From what your saying to start with i think it really is related to oil pump and oil and filter. I dont think anything to do with the work they have carried out its simply that its not been on the road long and problems are likely for a while. Unless it has a record of it then change the oil pump, filter, oil. County pumps are not expensive and its not a big job but you will need to tel them to reuse the original pressure relief spring as the new pumps are for Saab and the springs a bit strong for the Stag. Unless anyone knows if that's changed? If you can afford it get an oil pressure gauge, its best.
good luck!
nigel
good luck!
nigel
