Speedo cable
    Speedo cable
    When I stripped my car for bodywork restoration there was no speedo cable attached to the drive. My car is one of the last to be built and I am the only owner. Were later cars fitted with a different electonic system.
    1978 Stag Brooklands Green
    We bought a speedo cable from Peter LD parts his were a bit shorter in lenght,being that bit shorter makes fitting the cable much easier,i think auto and manual are different lenghts ours was manual we also used his angle drive
      .JohnS.
      Triumph never fitted an electronic speedometer in the Stag. Are you saying that yours has worked ever since you bought it new, without a cable?
        I took my car off the road in 1987. Up until then it was run and MOT'd. I changed the clutch once but there definitely was no drive cable neither at drive end or speedo when I removed engine and gearbox for rebuild. I'll check speedo electric tomorrow.
          Further to my previous post I have checked the speedo and I am really stuck for words. There was certainly no speedo cable when I started the strip down but I have no recollection of the cable being removed. See attached a picture of the rear of the speedo. I assume the attachment with the cable id tags is the 10v stabiliser. This is item No 53 on the wiring diagram. Can anyone advise it"s purpose.
            Hi
            It stabilises the voltage for the Temp & Fuel gauges so they read correctly. Someone will be along to give a more technical response!
            Jeff
              steady 10v for those instruments
                Not quite "steady" if you put a multimeter on the output. It contains a bi-metallic strip with a heating element so it switches battery voltage on and off proportionately to achieve 10V average. As the Fuel & Temp gauges operate using heating elements with bi-metallic strips connected to the pointers, the action is well damped, so it works quite well, mostly.
                Was quite innovative 50 - 60 years ago. Some folk have replaced the original with a 10V solid state regulator - each to their own.
                    Pretty sure my digital one is steady
