When I stripped my car for bodywork restoration there was no speedo cable attached to the drive. My car is one of the last to be built and I am the only owner. Were later cars fitted with a different electonic system.
Speedo cable
Further to my previous post I have checked the speedo and I am really stuck for words. There was certainly no speedo cable when I started the strip down but I have no recollection of the cable being removed. See attached a picture of the rear of the speedo. I assume the attachment with the cable id tags is the 10v stabiliser. This is item No 53 on the wiring diagram. Can anyone advise it"s purpose.
SPEEDO.JPGJohn
1978 Stag Brooklands Green
Not quite "steady" if you put a multimeter on the output. It contains a bi-metallic strip with a heating element so it switches battery voltage on and off proportionately to achieve 10V average. As the Fuel & Temp gauges operate using heating elements with bi-metallic strips connected to the pointers, the action is well damped, so it works quite well, mostly.Originally posted by Goldstar View Poststeady 10v for those instruments
Was quite innovative 50 - 60 years ago. Some folk have replaced the original with a 10V solid state regulator - each to their own.White 1976 build ("Mk2") only a few mods
Pretty sure my digital one is steadyOriginally posted by StagJonno View Post
- Likes 2
