Just had my front suspension fully refurbished with poly bushes, new track road ends etc and rack checked by reputable Stag specialist but still have play in steering wheel, is this ok?  Thought it would have removed the poly to be honest.
Play in Steering Wheel Triumph Stag
 Hi,
 The steering inner/outer column shafts have a set of interlocking splines that allow the steering column to extend. e.g. reach adjustment.
 Try extending the column and see if the amount of play changes.
 I found that the splines had worn so that there was always a slight amount of rotational play through the steering column.
 I purchased a second-hand steering column but unfortunately there was still some play.
 So, I tightened the lock nut/ring that holds the outer column to the inner column so that there was no rotational play but the position of the steering wheel can no longer be adjusted for reach.
 (No movement along the splines).
 I have attached pictures so that you can see the inner/outer shafts and the lock ring in question.
 regards,
 Den
