water pump stamped letters
    No problem whatsoever, in fact you beat me to it, lol.
    For clarification, the stamping on my pump shaft was "XL 04".
      Have noticed many different markings. Best to be sure & do the file test.
      However a collection of markings would / could be useful.
        Bump anymore water marking letters?
        Thanks
          Ct-zephyr
          all caps. Auto correct turned to lower case twice!
          must off mi poor splelling is du 2 auto correct.
            This is my pump from a 1974 Stag. HYR is the marking (unless there is another letter at the start).
              Last 3 letters of zephyr.
              The zephyr ones seem well made.
                Well spotted Julian!. Strange thing is I have about 6 pictures of the pump taken at different times and they all only show those letters. Sods law in action. It certainly seems good. That was taken at about 120K miles and there was no noticeable wear. I had to replace the jackshaft recently (150K miles) because of wear on the distributor/oil pump drive gear, but the water-pump gear was still fine.
                  Here is a pic of one from a Triumph Dolomite - not sure if it was an 1850 or a Sprint, but they are all the same. Stamped with U PA. Sent to me by a member of the Triumph Dolomite Club/forum. Will try to find out its history.
                  This gallery has 1 photos.
                  So many cars, so little time!
                    Bump , anymore known good/ hard water pump markings?
                      2nd request for stag waterpump hardness details that I had today
                      Machine shop should be able to gauge hardness but that is not cheap.
                      Some suggest a diamond file, if it doesn't mark then apparently fabulous.
                      Buying from a reputable source is no guarantee when it comes to good old New Old Stock - recovered from a skip 30 years ago and now being resold etc etc etc
                        I took parts to Wallwork to be heat treated.
                        They hardness tested some nos parts for reference…. They also did sprocket material check.
                        Wallwork have various locations.
                        I used (braved) Birmingham Small Heath
