Hi everyone, now reassembling rear drive shafts the back plate, is there a certain position that it attaches to the shaft or can you bolt it on anywhere. Many thanks Steve.
Rear drive shaft back plate.
Do you mean that you're concerned that your back plate has previously been fitted incorrectly and want to know if its ok to leave it, or are you wanting to fit it differently to what jbuckl and MandM describe for some reason and are asking if this ok? You could have problems with any insurance claim if you knowingly deviate from the original design of the braking system.Last edited by Philip Wardle; 24 July 2023, 09:06.
Definitely lost on this one if it's not the backplate where the wheel cylinder & Co are attached to as in the photos. Perhaps a picture which tells a thousand words?
Seite 159 Triumph Stag Graphic Catalogue PLATE L2 B1820 51.jpgLast edited by dasadrew; 24 July 2023, 15:46.The answer isn't 42, it's 1/137
Originally posted by NeilR View PostDrew, I think your illustration is upside down, wheel cylinder & h/brake lever go at the bottom don't they ?.
I have had disc brakes for years, but seem to remember the cable being under the suspension arms with standard drums.The answer isn't 42, it's 1/137
here's the ROM pic which exactly matches the photos posted earlier:
Stag ROM 1977 - 70 - BRAKE - 12.jpgThe answer isn't 42, it's 1/137
Originally posted by dasadrew View Posthere's the ROM pic which exactly matches the photos posted earlier:
