As the title says, is the rear end strong enough with the boot floor removed to have it on the spit,
It is ok to have the car on a spit with the boot floor removed
 Boot floor is already out, but I have supported the weight with a jack before I removed it, you can see at bottom right of photo, will weld some supports as you suggested if I need to flip it, would be easier to work on if I can flip it, but think I can manage in the position its in, lots wrong with the back end than needs fixingOriginally posted by mole42 View PostI would weld temporary box section triangular braces between the lock panel and the wheel arch on each side before taking out the boot floor.
