Hi Guys i tock my car to work with me today but to came on the back of a AA truckthe problem is the car will run for a short time and then cut out when it comes to a hill or when it gets warm i have renew the coil and the fuel pumpno change if you pull the choke out it will start but then will died please help as i am ment to be taking the car to a show this weekend.
Can any one help
Sounds like a fuel problem check that you are getting fuel up to the carbs and enough Why did you change out the parts.
If you can eliminate the pump and fuel delivery ie enough of it and the pressure then check that you are getting the same through the filter. Make sure the pump stays running with the ignition in the run position an electrical problem in the system can cause the pump stop running. Eliminate one system at a time and write it down then do basic checks spark, coil lead, check distributor, check timing
Did it ever do this before?
sax player
steve 1 wrote:Has to be fuel. Prove you have fuel to the carb be taking the fuel connection off put the ignition on and allow the pump to fill a suitable container,Hi Guys i tock my car to work with me today but to came on the back of a AA truckthe problem is the car will run for a short time and then cut out when it comes to a hill or when it gets warm i have renew the coil and the fuel pumpno change if you pull the choke out it will start but then will died please help as i am ment to be taking the car to a show this weekend.
if this is ok check youre float settings in the carbs and the little needle valve is not jammed shut.
shaun
