Hi running with 13lb cap on Mk1 Stag, seems to be passing a bit would a20lb,be ok sometimes coolant not returned to rad have to do it manually,Thanks Guys
RAD Cap
Guest
Hiya Doug, welcome, sit a while, make yourself comfortable, it's a good place to be.
First, are you sure you have a Mk1 cooling system ? Is the pressure cap on top of the rad, or on the expansion bottle ? If on the radiator it's Mk1, on the expansion bottle, Mk2. Many owners converted the earlier cars, it's not an issue providing you know.
Martin.
