just started underneath jobs this weekend and replaced clutch slave cylinder,overdrive solenoid and inhibitor switch with good results all round, next job is the engine oil cooler and noticed there aint a lot of room to get the pipes from the new oil filter housing up to the cooling rad which i assume mounts low down on front of the engine and behind the grille.anyone fitted one of these ? could do with knowing where it all goes.
pete.c :?
pete.c :?
