I know this will have been asked a thousand times , but I can't seem to filter an answer on here , probably my fault.....anyway ,rambling sorry........what should the oil pressure be at 3000rpm  with the engine at running temp ?
Oil Pressure
 Originally posted by Mrs hoskins View PostI know this will have been asked a thousand times , but I can't seem to filter an answer on here , probably my fault.....anyway ,rambling sorry........what should the oil pressure be at 3000rpm with the engine at running temp ?
 50 ish PSIWise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
 I recon mine to be good at 45 psi idle and 60 psi above Eg 2000 rpm GrahamOriginally posted by Mrs hoskins View PostI know this will have been asked a thousand times , but I can't seem to filter an answer on here , probably my fault.....anyway ,rambling sorry........what should the oil pressure be at 3000rpm with the engine at running temp ?
 Oops ! Hot idle on mine can be as low as 15 psi - It's on the 'to-do' list, however I'm happy that, provided I don't thrash the bo****ks off it then it'll be ok for some time to come.Originally posted by Staggard View PostI recon mine to be good at 45 psi idle and 60 psi above Eg 2000 rpm Graham
 Julian.
 That's Ok J, mine is 20 psi hot idle. Mr Triumph was quite happy to let it go below 5 psi before the worry light came onOriginally posted by jleyton View PostOops ! Hot idle on mine can be as low as 15 psi - It's on the 'to-do' list, however I'm happy that, provided I don't thrash the bo****ks off it then it'll be ok for some time to come.
 Julian. Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
 Thanks Ian,Originally posted by milothedog View PostThat's Ok J, mine is 20 psi hot idle. Mr Triumph was quite happy to let it go below 5 psi before the worry light came on
 I 've not been too worried about it but it's reassuring to hear that a professional like you is equally happy about it.
 Cheers, and a Happy New Year to you.
 Just to add to that, IIRC the Rover V8 runs at 30 psi at higher rev'sOriginally posted by jleyton View PostThanks Ian,
 Julian Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
 Perfectly OK at that Julian. Graham must have a HP pump fitted. The jury is still out as to whether pressure that high is good or bad. There have been plenty of discussions about it in the past.Originally posted by jleyton View PostOops ! Hot idle on mine can be as low as 15 psi - It's on the 'to-do' list, however I'm happy that, provided I don't thrash the bo****ks off it then it'll be ok for some time to come.
 Julian.Dave
 Yep, we used to get occasional reports of oil light coming on (ie 5ish psi as Ian says) during the warranty periodOriginally posted by DJT View PostPerfectly OK at that Julian. Graham must have a HP pump fitted. The jury is still out as to whether pressure that high is good or bad. There have been plenty of discussions about it in the past.
 Originally posted by jleyton View PostYep, we used to get occasional reports of oil light coming on (ie 5ish psi as Ian says) during the warranty period
 Yep V8s just lllluuuuurrrrvvvve FLOW not pressure. Rover V8s run at about 30lbs pressure at revs over 2000 and the warning low pressure sensor comes on at 5 lbs. My race engine had gated sump with swinging gates and big wings and increased pressure sensing warning at 15 lbs and I could still make it blink on high speed instantaneous right turn corners.
 Stag runs at 25lbs on hot idle and 40 lbs at revs over 2000.
 Micky
 I prefer ignorance. The Grey Lady has an oil pressure gauge and runs at 25lbs psi when hot at 45 mph . When it developed a problem in 2002, I drove back from Brittany to Paris with just about 12 lbs psi. When I contacted Red Triangle the person at the other end of the telephone simply stated 'you've got oil pressure!'.
 My Stag has a gauge and the previous owner removed this relying instead on the warning light. I drive and enjoy the rumble of the V8 without thinking anymore of the matter. After all one does have to keep an eye on the temperature and find those oil leaks. Is that not enough?
 Originally posted by RobinLegin View PostI prefer ignorance. The Grey Lady has an oil pressure gauge and runs at 25lbs psi when hot at 45 mph . When it developed a problem in 2002, I drove back from Brittany to Paris with just about 12 lbs psi. When I contacted Red Triangle the person at the other end of the telephone simply stated 'you've got oil pressure!'.
 Ignorance is one thing Robin but ignoring low oil pressure is another. In real terms it's the difference between trashing a crankshaft or being able to reuse it if the issue is addressed early or paying for another (£500 ish ) if you leave it, on top of what is required to rebuild the  engine. Dash gauges are not reliable and a calibrated gauge will give you a true reading but low oil pressure is not to be ignored ) if you leave it, on top of what is required to rebuild the  engine. Dash gauges are not reliable and a calibrated gauge will give you a true reading but low oil pressure is not to be ignored
 Ian.Last edited by milothedog; 30 December 2015, 19:28.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
 Ian - are the SOC saying the oil pressure warning light is of no use? Surely not. Once started the oil light goes out and never comes on (and neither does the ignition light) until the engine is switched off. I accept you point about trashing a crankshaft and I certainly don't have a spare £500 to spend. But what is the point of of the warning light otherwise?
 Nigel
